Jimmy Dean Mac Posted December 15, 2021 Share Posted December 15, 2021 I have a 2014 bobcat T770 The glow plug cuts off too quickly when you unplug coolant temp sensor it will countdown normally dealership put a new coolant temp sensor in it did not change anything Shop ran all the test everything comes back normal but glow plug will not count down as long as coolant temp sensor is hooked up does anyone have any ideals Dealership could not figure it out (so $2500 later they’re returning machine to me still no glow plug…(they did replace fuel sending unit and AC blower motor in the $2500 but was still disappointed with all the labor they charge me N did not fix the glow plug) thanks jimmy Quote Link to comment Share on other sites More sharing options...
thebunns Posted December 16, 2021 Share Posted December 16, 2021 The glow plug on my Chinese Rhino went bad & when I put a new one in its design was such that I twisted the hot wire off by merely tightening it in the manifold. I found that one shot of ether just prior to turning the motor over makes it start immediately. Vic Quote Link to comment Share on other sites More sharing options...
hardtail Posted December 16, 2021 Share Posted December 16, 2021 What's this hobby horse Vic😲 And why after all these years are we just learning of this now? To the OP question I don't know when society switched but there seems to be a never ending expectation to be paid well to never solve your problem, if you installed swimming pools and drove your equipment past their house would they roll out the Benjamin's for your half hearted attempt to deliver what they asked for, once again your better trying to repair yourself because no one has a greater interest in your equipment than you, I have learned this time and time again and when I forget just take something to a shop to reinforce what you already knew 1 Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted December 16, 2021 Share Posted December 16, 2021 What controls the glow plugs? Is it part of the ecm or does it have a separate controller? Is it possibly a software problem? Every time I hire a dealer to work on something, I remember why I don’t hire dealers to work on anything. 1 Quote Link to comment Share on other sites More sharing options...
thebunns Posted December 16, 2021 Share Posted December 16, 2021 Hardtail, To your second question---I don't know! As to the first these tractors, made in China were sold here (mine came from Jerome Idaho) as demonstrators. Hobby Horse Ranch sold it to me. Mine had 7 hours on it. I got it in 2003 to plow my driveway but found out real quick that I needed my TD-14 & -14A with their blades built up 18" to do the job. It usually takes both to have one running come spring. That Rhino turned out to be quite light. I've bent the blade digging rocks out of my driveway & the tracks have to be kept as tight as a violin string to keep them on the rollers. Good enough? Vic 1 Quote Link to comment Share on other sites More sharing options...
hardtail Posted December 16, 2021 Share Posted December 16, 2021 Lol yes once again 70 yr old American Iron better than brand new Asian Quote Link to comment Share on other sites More sharing options...
mmi Posted December 16, 2021 Share Posted December 16, 2021 for the most part (less than 50 yrs in business with original employees )stealers know nothing and the MFG wants it that way. some of my best buys come from theirs shops back doors 5x more broken than in the front. no easy to do ,YOU must do the research on the schematics and function of each part and then fix your self gp timer,bad signal from x ,glitch in program as said, under warranty? Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted December 17, 2021 Share Posted December 17, 2021 What did the fuel sending unit and AC motor have to do with the glow plugs???😵 Did they check all of the wiring to the coolant temp sensor? Quote Link to comment Share on other sites More sharing options...
scoutring Posted December 20, 2021 Share Posted December 20, 2021 Did you check for voltage at the glow plugs to see if there is voltage there ? Ok next, Did you check to see if there voltage is present, 0r how long ? No Voltage ! What powers the glow plugs ? A timer, Relay, or the machine computer ? Timer can be bad. replace it. The relay bad, replace it. Does the wiring check out ok, or is one of the wires going to the glow plugs broken. Maybe a bad ground ? Computer's timer needs to be checked for the heat up time for the glow plugs. OR when all else fails By pass the current system - and you could install a new timer and wiring to control the glow plugs, With a push button to activate the the new timer system. You will probably get an error code from the computer after modifying the system, but the motor will start and it should not affect how the equipment runs and operates. Good Luck ! Quote Link to comment Share on other sites More sharing options...
