Rusty shackleford Posted December 10, 2021 Share Posted December 10, 2021 I'm a fan of 11.00 15s on the smaller tractors, with 8 bolt hubs, dont care of its overkill I just like the look 3 Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 11, 2021 Author Share Posted December 11, 2021 8 hours ago, just Dave said: I'm curious too? @Long Farms Hyd winch welded on weight bracket. Had to grind and cut it off and take winch back to him. Guy said he'll just torch it off on the spot. I told Johnny cuttn torch **** no i do it at my shop with my tools since it was now my weight bracket. 1 1 Quote Link to comment Share on other sites More sharing options...
acem Posted December 11, 2021 Share Posted December 11, 2021 Nice tractor, I hope it works out well. A friend has a salvage yard, Dumas Tractor Salvage. You can call them and order one directly or have me pick one out when I go down. If you call them directly you can get it quickly but they don't always pull nice parts. I can get you nice parts but I don't make it down very often so you have to wait. Thx-Ace Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 12, 2021 Author Share Posted December 12, 2021 Added coolant conditioner kit off salvage 1066. Top line fits perfect had to make bottom line. Drained all the oils. Both engine and hyd oil looked decent. New set of Firestone 9.5-15 4 rib and good used 15.5x38 firestones on powder coated rims I had sitting out back. 8 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted December 12, 2021 Share Posted December 12, 2021 Very nice. Did the elbow fitting on the end of the oil cooler clear the frame rail or did you have to remove the cooler to install it? Looks like it cleared. On the two 1066’s we’ve done….they sit to close to the rail to turn. Would those rims be 15” wide? Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 13, 2021 Author Share Posted December 13, 2021 Oil cooler elbow clears frame rail while turning. Think the rim is 7" or 8" wide. Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 17, 2021 Author Share Posted December 17, 2021 Last owner said they pulled the 666 out of the mud and wrapped chain around axle. Axle seal was pouring oil. Busted wheels loose and noticed gap around axle cap looked odd. Measured axle tip height and turned 180*. They bent the damn axle...... Decided to go ahead and strip it down further where it sits. Blew off majority of the crap and crud. Im gonna set up a portable water tank and power wash the 666 where it sits before i tare into it. 6 Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted December 17, 2021 Share Posted December 17, 2021 Well FUDGE....bent axle (could be worse I suppose). Hey, while you got the tranny tore down....measure up/spec the oil filter cover plate & housing opening so we can get a spacer made..😁 Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted December 17, 2021 Share Posted December 17, 2021 Nothing is ever simple........ You will have it back in fighting shape soon. Quote Link to comment Share on other sites More sharing options...
bitty Posted December 17, 2021 Share Posted December 17, 2021 3 hours ago, Jeff-C-IL said: Well FUDGE....bent axle (could be worse I suppose). Hey, while you got the tranny tore down....measure up/spec the oil filter cover plate & housing opening so we can get a spacer made..😁 I wouldn't be surprised if Brian has a set of long axles, hubs etc setting out back with rattlesnake guarding the parts pile 1 Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 17, 2021 Author Share Posted December 17, 2021 Ive never seen long axles for a 6. Parts list doesnt show it on line. What it does need is front mount hyds. I have set of 656 axles thats all thr same P/Ns. Sold a set of 686 axles last week so that was a close call. I power washed it more today and its starting to clean up finally. Next week ill pull fuel tank and bracket and get real hard spots. Also started putting wire harness order together. Wont get any easier to rewire than tore down like it is. 6 Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted December 17, 2021 Share Posted December 17, 2021 I put new wiring on mine from Porch's. There was one wire that was not long enough on the dash harness, think a green one. Told Eric to make a change, no idea if it happened. Everything else was great. Just FYI - not sure your supplier. Quote Link to comment Share on other sites More sharing options...
Long Farms Posted December 18, 2021 Author Share Posted December 18, 2021 I only buy and deal with Porch. Theyve treated me well over the years for several tractors. I like being able to talk to the man making the harnesses. 3 Quote Link to comment Share on other sites More sharing options...
Steve C. Posted December 21, 2021 Share Posted December 21, 2021 On 12/10/2021 at 10:38 AM, nepoweshiekfarmalls said: The lines are slightly longer on the 400 series, but I think you can make them work. I brought a used kit home from work last spring to install on mine and spent some time looking it over. My issue was the M&W turbo filter in the way. So, I put the project on hold for the moment. Would still like to do it sometime. That kit will work. I put one on my 766 as soon as they were available. Don't remember if we had a line made up or bent the original, but it worked. Quote Link to comment Share on other sites More sharing options...
Long Farms Posted January 9, 2022 Author Share Posted January 9, 2022 Removed bent axle and installed used axle and housing off a 656 hydro. Not a bad chore but getting axle splines to line up with bull gear sucks. Some gunk build up in rear end but not bad. PTO suction tube screen completely stopped up. Draft sensor U bolt was broke and top end that touches draft finger on top plate had be caught by bull gear and smashed. Never know what youll find tore up when you open em up. 4 Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted January 10, 2022 Share Posted January 10, 2022 You make things look so easy!! Is that your line up of red tractors out ahead of the 666?? Quote Link to comment Share on other sites More sharing options...
Long Farms Posted January 10, 2022 Author Share Posted January 10, 2022 Thats skid row. IHs waiting their turn to be fixed up. Basicly just been stacking them up if they have potential to get going again. 966 in the mix needs to be parted though. One if these days there won'tbe any left around to buy. All thatll be left is whats stacked out back. 1 1 Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted January 10, 2022 Share Posted January 10, 2022 As per earlier comment.... While you got the tranny tore down....measure up/spec the oil filter cover plate & housing opening so we can get a spacer made for the deeper filter...😁 Quote Link to comment Share on other sites More sharing options...
beekeep15 Posted January 10, 2022 Share Posted January 10, 2022 wondered how those triangle stands were used. is tractor bolted to stand? appears to be just setting on it. Quote Link to comment Share on other sites More sharing options...
Long Farms Posted January 10, 2022 Author Share Posted January 10, 2022 Bolted on drawbar support. Another cradle on the front of triangle. 1 Quote Link to comment Share on other sites More sharing options...
beekeep15 Posted January 10, 2022 Share Posted January 10, 2022 thanks Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 10, 2022 Share Posted January 10, 2022 On 12/8/2021 at 8:36 PM, Long Farms said: Apparently Firestone 7.50-16 are out of stock nation wide. Might have to drop down to the 15" rims i have. I might have a set if your interested Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted January 10, 2022 Share Posted January 10, 2022 On 12/10/2021 at 1:44 PM, Jacka said: My Hydro 70 has water filter/ treatment. 312 motor On 12/10/2021 at 6:33 AM, mrfred54 said: Nice find. 666 are a nice size tractor for all types of jobs. Happen to be overhauling one right now. Has a pin hole in a sleeve and crankcase filled with antifreeze. Doing a out of chassis rebuild. Owner is leaning towards reliance kit for $2100. Are these good rebuild kits, has anyone had experience with them. Also replacing injectors and injector sleeves,head redone, radiator getting sent out to get rodded out. Also rebuild the pto, this tractor lives on feed grinder. Tach shows 1348 hours. I don't believe water filter kits were available for the 300 series engine, does anyone know if they were or still are?? check with restoration sales in PA. he was selling OEM IH kits last fall for around $1500 Bitty may have some input on it he deals with them Quote Link to comment Share on other sites More sharing options...
bitty Posted January 10, 2022 Share Posted January 10, 2022 53 minutes ago, m.c.farmerboy said: check with restoration sales in PA. he was selling OEM IH kits last fall for around $1500 Bitty may have some input on it he deals with them On 12/10/2021 at 6:33 AM, mrfred54 said: Nice find. 666 are a nice size tractor for all types of jobs. Happen to be overhauling one right now. Has a pin hole in a sleeve and crankcase filled with antifreeze. Doing a out of chassis rebuild. Owner is leaning towards reliance kit for $2100. Are these good rebuild kits, has anyone had experience with them. Also replacing injectors and injector sleeves,head redone, radiator getting sent out to get rodded out. Also rebuild the pto, this tractor lives on feed grinder. Tach shows 1348 hours. I don't believe water filter kits were available for the 300 series engine, does anyone know if they were or still are?? Definitely give Jesse a call at Restoration Tractor sales (717)682-6263 . Leave him a message if he doesn't get to the phone and he will get back to you. I got a 414 and a 436 kit from him last year. I am waiting for the block currently to install the 414 kit 1 Quote Link to comment Share on other sites More sharing options...
mrfred54 Posted January 10, 2022 Share Posted January 10, 2022 4 hours ago, bitty said: Definitely give Jesse a call at Restoration Tractor sales (717)682-6263 . Leave him a message if he doesn't get to the phone and he will get back to you. I got a 414 and a 436 kit from him last year. I am waiting for the block currently to install the 414 kit Thanks bitty. Went with reliance kit. All back together, and customer has it back. Will keep his number for future use Quote Link to comment Share on other sites More sharing options...
