Hydraulic pump gear removal
Hectoe
I am working on a internarional 1086 i need to remove the hydraulic pump drive gear can you guys help me out on how to remove the shaft that drives the gears this is my first international i have encountered hope you guys can help me out thank tou in advance
Are you wanting to remove the Driven gear on the pump itself ? Or remove the drive gear on the IPTO shaft that drives the pump? Also which Hydraulic pump do you have the old style gear pump or the PPH piston pump?
