1063 corn head
IHC5488
Pretty far from you but Colfax Tractor in Iowa should have about anything you could want/need. Call; 515-674-3001.
You can probably find them closer but those guys have combine parts like crazy. Quite a resource to have 7 miles away when something breaks during harvest.
Don't mean to steal this thread but does anyone have trouble with a 1063 with one row always plugging with stalks. Have changed knives, adjusted rollers in and out, and can't see any difference from the other rows. This same row always gives us headaches. Any suggestions as what to try????
What condition is the little triangle piece in back of stripper plates look like?
48 minutes ago, mrfred54 said:
That triangle piece is worn and looks tipped down a fraction lower than the other ones. Is that replaceable??  Does not really look that much worse than the others
They are replacable, i put a set on a 863 yrs ago. they are weld-on
Are the stalk rolls tight on the square gearbox shafts? Dad had a 1044 that would plug one row, the couplers and shafts were worn enough that the knives wouldn't stay in time. Replaced them and everything worked as it should
There new, square shafts,knives,water pump style bearings,left and right gathering spindles. The little triangle piece at the top of the stripper plate is only thing left, didn't know they were replaceable. Gonna check with case IH dealer, see if there available
