7140 shifts hard between 6 and 7
jdetig1
My 7140 shift a lot rougher between clutch pack such as 6-7 and 12-13 than any of our 7120 tractors. Is that just the nature of the beast or is something wrong or some adjustment need to be made? While chiseling shifting up or down between 6 and 7 is darn rough.
Start by recharging the accumulators that are behind the batteries on the left side of the tractor. They are 2 round canister's that face forward off the transmission control valve. Take them off and have your local dealer recharge them with nitrogen. Most of the time they will take a charge but sometimes the bladders inside them will burst in which you will have to get a new accumulator.
Accumulators we’re charged this spring. Maybe one could be bad or something idk. Seemed like it shifted delayed or too soft before I had them charged.
could it be regulated pressure in the transmission is just higher on the 40 series than the 20 series causing a harder shift?
Regulated pressure should be the same. An accumulator can go bad at any time or have a slow leak
2 hours ago, jdetig1 said:
Accumulators are all the same correct? So I could just swap ones off my smooth shifting 7120 and put them on my rough shifting 7140 to see if anything changes.
Same thing and same pressure so yes
On 12/3/2021 at 10:44 AM, 756puller said:
The mx270 can be calibrated thru the a post but it does have an accumulator also
The transmission (regulated) accumulator did not appear until the next generation MX Magnums.
