986 differential lock
gafarm49
I am just thinking but I would start hooking a test light to the wires and make sure it's not getting electric when it is not pushed
5 minutes ago, gafarm49 said:
Its a mechanical knob you step on that engages the plunger
Ok I thought it would be a dimmer switch looking electric button like my 186 has . Thought the 66 was like you are describing
33 minutes ago, 606 diesel said:
This is an early 986 isn't it? If so it sounds like your spring lost tension or broke. Part number should be 113797c1 for the spring and the o-ring is 364885r1.
Yes thanks!!! Sounds like thats it!
Funny story relating to diff lock.  My hydro 100 is the first machine I have owned with it installed.  I went to move the tractor this spring and as I went to make a sharp turn, the tractor shook and resisted the turn.  I was confused what was going on and pulled the hydro lever to neutral and stopped.   Started looking around and discovered my prosthetic foot was resting on the actuator assembly!  Ooops! 😖 Moved my foot forward and all was well again. I guess it does work!
