Removing and installing the range transmission cover on the 706-1206
Red Tech
Like most things that I have learned, I remember them best when I do them wrong the 1st time.
Maybe all of you know this, but in case you don't, the best way to remove the range transmission cover on the 706-1206 is with it shifted into high range; any other position will lift the reverse shift shaft out of the reverse shift fork.  If that happens, you risk having the small 1/2 moon key fall into the transmission.
I work on these so seldom, that it is easy to forget.
Red Tech
I always took them off in neutral myself but to each their own you will see other's ideas soon only thing I ever was concerned about was the parking pawl coming apart
