IH686neuss Posted November 17, 2021 Share Posted November 17, 2021 Has anyone turboed a 5130. Wondering what was used and what ya use it for. Im looking to possibly do it to mine i use it for tillage. Quote Link to comment Share on other sites More sharing options...
CIHTECH Posted November 17, 2021 Share Posted November 17, 2021 Done many of them years ago, even easier today as parts yards have more 51-5240 tractors than back in early 90's when people were buying. Just buy everything from a 40 and bolt it on, set pump up a bit, should end up around 115-120 hp. Would advise checking / adjusting regulated pressure to spec. might save ya some headaches. If regulated is running a little low and you throw a turbo at it possibly and tie her down you could end up rebuilding power shift, shuttle or pto. Quote Link to comment Share on other sites More sharing options...
IH686neuss Posted November 18, 2021 Author Share Posted November 18, 2021 I was wondering if that was a good way to do it. Might have to look into that. About 20 more hp would be perfect. A different tractor is kinda out of the budget at the moment. Its has just under 4000 hrs so its got alot of life left Quote Link to comment Share on other sites More sharing options...
DirtBoyz07 Posted November 18, 2021 Share Posted November 18, 2021 I did one a few years ago and it worked out great but the 30’s have a CAV pump and full fueled I could only get 120 hp out of it , they are a great motor and it will run just fine at 300 hp if you could get the fuel to it , not sure how the Maxxum would handle it 😳 if you ever wanted more you would need to change out the front cover so you could put the inline Bosch pump on it . There are two of them near me that I set up to 165 on 5240’s and bumped up the rpms for filling silo , both of these tractors are well part 10,000 hrs . Danny Quote Link to comment Share on other sites More sharing options...
