Harvester66 Posted November 11, 2021 Share Posted November 11, 2021 I would like to install AFX style rotor in my 1688, wondering how late of model combine will fit. I found a 7130 in a salvage yard they are not sure if it will fit it isn’t out yet so can’t compare. They did say coupler on the back is 8 bolt instead of 6, but if splines are the same it doesn’t matter. I have also thought about Abilene machine after market bolt in kit. Quote Link to comment Share on other sites More sharing options...
brahamfireman Posted November 11, 2021 Share Posted November 11, 2021 Do you have a specialty rotor now? Of so I'd just add the kit up front and keep what you have unless your rasp bars are shot, then it might be cheaper to find a good afx rotor. Quote Link to comment Share on other sites More sharing options...
Harvester66 Posted November 11, 2021 Author Share Posted November 11, 2021 No i have a standard rotor. Quote Link to comment Share on other sites More sharing options...
jass1660 Posted November 11, 2021 Share Posted November 11, 2021 Word of caution on an afx rotor, in green stem beans they don’t rumble like a standard rotor until you plug the rotor... Quote Link to comment Share on other sites More sharing options...
tractorholic Posted November 12, 2021 Share Posted November 12, 2021 I had a standard rotor in a 1680. The elephant ears were cracking off where they fastened to to rotor. I found a afx out of a 2388 that was salvaged. I didnt care for it. Its hard to not spit kernels out the rotor in corn. I dont see the threshing advantage in beans either. A hard time threshing all the pods. I agree that it doesn't rumble. Your in trouble before you know it I think Id stick with a standard rotor. (Im sure I will get bashed for saying that) Quote Link to comment Share on other sites More sharing options...
ole 815 Posted November 12, 2021 Share Posted November 12, 2021 2 hours ago, tractorholic said: I had a standard rotor in a 1680. The elephant ears were cracking off where they fastened to to rotor. I found a afx out of a 2388 that was salvaged. I didnt care for it. Its hard to not spit kernels out the rotor in corn. I dont see the threshing advantage in beans either. A hard time threshing all the pods. I agree that it doesn't rumble. Your in trouble before you know it I think Id stick with a standard rotor. (Im sure I will get bashed for saying that) Totally agree with what he said 👍 Jus put the kile flights on your Standard Rotor, Rebuild your threshing area, new vanes, rotor bars etc. It will perform fine. Your not missing a thing by not having an AFX......well except throwing corn out the back. It's a Rice Rotor! Not a corn Rotor Quote Link to comment Share on other sites More sharing options...
SDman Posted November 12, 2021 Share Posted November 12, 2021 The rotor should fit, but the coupler will need to be changed. Later gearboxes used a 23-spline drive, older gearboxes like yours were 17-spline. Quote Link to comment Share on other sites More sharing options...
supermpuller Posted November 12, 2021 Share Posted November 12, 2021 I had a AFX rotor put in my 2188 best thing I ever did to improve grain smaple and running speed Quote Link to comment Share on other sites More sharing options...
Harvester66 Posted November 12, 2021 Author Share Posted November 12, 2021 Thanks for input, I should have said I don’t harvest corn. wheat, beans, milo. Also thanks SDman if I decide to go that route that’s the kit I’ll need. Quote Link to comment Share on other sites More sharing options...
