pt756 Posted October 24, 2021 Share Posted October 24, 2021 Helllo again, in our barn we have 2 inch pvc under the stalls to bring water to the cows, one section must have a build up in, is there a snake or something that would be at least 75 feet long, it is a gravity water system, thanks for any help Quote Link to comment Share on other sites More sharing options...
zleinenbach Posted October 24, 2021 Share Posted October 24, 2021 If it’s clogged solid hook a shop vacuum up to downstream side. I guess that’s assuming electric is available. there are snake cables that are tgat long but would be expensive to buy for just a one time use? Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted October 24, 2021 Share Posted October 24, 2021 Can you get a straight shot on it?if so you could stuff 1/2” conduit down to poke the crud loose Quote Link to comment Share on other sites More sharing options...
AKwelder Posted October 24, 2021 Share Posted October 24, 2021 Flush from down stream if you can, some places rent waterjetters, which are pulsing and eat it out. We have also used a length of PEX with water and flushed it from downstream Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted October 24, 2021 Share Posted October 24, 2021 Air pressure. Quote Link to comment Share on other sites More sharing options...
junkandcattle Posted October 24, 2021 Share Posted October 24, 2021 3 minutes ago, vtfireman85 said: Air pressure. Back when we relied on a gravity line from ponds it was an annual event to apply air pressure to clear the silt out. Granted they were just 1 " lines but it worked. Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted October 24, 2021 Share Posted October 24, 2021 Get a sewer jetter nozzle for a pressure washer and run it up there. 1 Quote Link to comment Share on other sites More sharing options...
Steve C. Posted October 24, 2021 Share Posted October 24, 2021 This would be a cheap, easy fix. I use one occasionally. Works well on most plugs. Hook it up to a garden hose and pressurize the upstream side. Put it in the pipe just far enough that the bladder will seal against the sides of the pipe when it inflates, turn the water on, and let it go. No downside that I'm aware of. Make sure you get one for 2" pipe. 1 Quote Link to comment Share on other sites More sharing options...
pt756 Posted October 24, 2021 Author Share Posted October 24, 2021 thanks for replies, the problem we have is that every 8 feet there is a tee that lets the water up into the 10 inch pipe for the cows to drink and if there isnt a tee then there is an elbow at one end to allow it to be drainedm when we rebuilt the barn after the fire 25 years ago, we wanted to get away from drinking cups back then, so these gravity water systems were used in a stall barn, was probably the same in some of the older free stall barns back then, we have very little trouble overall, just an occasional hudson bottle float, but there is this one section where the pipe goes under the holding area, i am thinking there is a buildup, thanks Quote Link to comment Share on other sites More sharing options...
12_Guy Posted October 24, 2021 Share Posted October 24, 2021 If these fittings are pressure fittings instead of drainage you will have a tough time getting a snake or jetter around the turn. Drainage or DWV fittings have a radius to them. Pressure fittings have a sharp 90 turn. The drain king pictured above may actually work. I don’t have much use for them on drains because unless you know there is no branch off of the line between it and the clog, you can be just pushing water up the branch which can cause problems. Quote Link to comment Share on other sites More sharing options...
oleman Posted October 24, 2021 Share Posted October 24, 2021 We have honda powered diaphragm pump (positive displacement trash pump) that could probably clean out the blockage. Quote Link to comment Share on other sites More sharing options...
ky966boy Posted October 25, 2021 Share Posted October 25, 2021 10 hours ago, Steve C. said: This would be a cheap, easy fix. I use one occasionally. Works well on most plugs. Hook it up to a garden hose and pressurize the upstream side. Put it in the pipe just far enough that the bladder will seal against the sides of the pipe when it inflates, turn the water on, and let it go. No downside that I'm aware of. Make sure you get one for 2" pipe. We used to use one like that in the milk barn Quote Link to comment Share on other sites More sharing options...
