2388 hyd press warning light
IHC Mark
2388 on soybeans all systems working great. Then hyd pressure light flashed a few times and on and off. I shut it down. Thought I had a leak and losing oil. No leak. Tank was a bit low so I decided to change filters and Hutton. Got done about dusk, decided to run it a bit to see if all ok. Ran 2 dumps, all perfect. Decided to quit for day. But when driving back to cart and pickup, dang hyd light flashed a few times. What is my gremlin. Is the pressure light for the hydro pressure or the belt driven aux pump, or both??
also I had driven it 24 miles to this farm in road gear, it pulled hills fine.
thanks for thoughts,  experience, suggestions etc.
There really isn’t any “hydraulic pressure light” on the instrumentation for a 2388. There’s a light for low hydraulic oil level in the reservoir and another warning light for high hydraulic oil temperature, but nothing for hydraulic pressure of any kind. Might want to double check what warning light is coming on for sure.
