Rocker arm shaft
Hello everybody...new member here, hope im posting in right spot. Question I have is, I have a IH 966 with damaged push rod. It's the first one towards the front of the motor. There was a snap ring at the end of the rocker arm shaft, but rocker arm wont come off shaft. Am I going to have to remove entire rocker arm shaft assembly to get 1st rocker arm off???
It sounds like you have a tiny burr at the snap ring grove. Try a little smooth file or fine sand paper on the groove. good luck!
