766 gas. Weak spark on 2 plugs. No spark on all other plugs.
MarkB
I'd start backwards from the distributor cap.  Check all connections, especially between coil and distributor.  Check points, maybe set too close?  If all that checks out, try a coil.
Also had a generator once that had an internal arc when it got hot.  That did some weird stuff.  That was on a 706 gas.
how did this become? tractor running and stop? or went to start it and no go? first check point gag and set also clean points.  quite possible its the condenser. a bad coil on a running tractor will be hot to the touch.
  • 1 month later...
