Correct weight color for an international 385?
Found a set of weights I forgot i had saved for the 385. Should they be red? It’s sort of an unusual tractor and I can’t say I have seen one with weights.
The first year 385's were IH and the second year and after CIH. If the engine, trans, rear etc is red then the weights would be red as well.
It is an 85 and yes, it is red.
3 hours ago, 495man said:
Red, you talking wheel weights?
Front weights should not be needed unless the 2200 is off and you have a real heavy 3pt item.
Rear.
