New hitch for pulling truck
Finney
Well......I can tell you what the weak link won’t be..... 😊
Looks very nice as usual. Always enjoy your work pics.
58 minutes ago, Finney said:
They wanted the old hitch removed and a new one installed. This is what they got.
beautiful finney next time they come back they will want you to make them a new truck to go wtih the hitch
  • Haha 2
18 minutes ago, Dasnake said:
Could you explain the hitch? A bit more heavy duty than average.
You try to build the hitch where it will pull down as much as possible. The turn buckles are to adjust the  height from the ground. All the tubing on the rear and the braces from the frame to the rear end is 2"X1/4" square tubing. The pieces the drawbar is attached to is 3'X1/4" with 1/2" ears for the drawbar. the drawbar is 2-1/2"x3/8" square tubing. The eye is a machined piece.
They have hit us up for a complete new chassis this winter. I have not agreed yet as I already have one to build.
Why does the phrase "think you used enough dynamite (steel) there butch?" Come to mind? Looks stout finney. Nice work as always.
