Massey Ferguson 4225 wont run
bmk
Tractor will start, runs for only 15 to 20 seconds and dies.  Changed the fuel filter, primer pump, electric selonid on injector pump. Still doing the same thing.  Any suggestions before we take the injector pump off?  Thanks
Tractor would die just like you cut the switch off.  Wait about 15 seconds and it would crank back up, run again for just a few seconds and die again.  No priming or anything.   We finally found the return line on top of filter base had a banjo fitting that was plugged stopping the return.  Cleaned it out and running great again.  Thanks again for the replies.
