Source for a Single Piston Ring
KWRB
I broke a compression ring today. Does anyone know of a good source for a less-than-full-kit piston rings for a C113.
Your machine shop can get any number of rings from Hastings.
best to settle for 1 piston set and move on ... IF found and they will let you
Mr Hastings would personally do it but today ,all the BS of shipping ,cross shipping, broken set fee, stocking fees and the child that is going to send you the wrong one
your machine shop can source rings by size as opposed to application, I would suggest talking to the guy out back not the counter help
 A&I sell them by the piston set if you can determine if they are the same size as yours-
A-PR113
Overbore 3" To 3-1/8"
Not For Use On OEM Pistons.
    Includes: 2 compression rings and 1 oil ring.
2 COMP RINGS, .090 THICK, 1 OIL RING .1795" THICK RINGS ARE SOLD PER CYLINDER, 4 ARE NEEDED PER ENGINE
