Is a 13mm Ambac 100 able to be used for farming?
RyanF
Just wondering if a 13mm pump would last a while when used for farming.  It would be going on a 5088.  I would also do larger injectors and injector lines at the same time.  Would this work, or would it make the tractor a fuel hog or unreliable.  It would go on a round baler, or manure pumps, and watched closely.
If it has the advance in the pump and you put a fuel capsule back in the pump and stock springs back in the pump you can only get it down to about that 250 hp range . I would tell you to just change the pump out from pulling to farm and you can run the injectors and lines if you want just make sure you have clean fuel , good fuel filters put additive in the fuel so you keep your injectors working correctly.
Danny
Don't suggest it. Hard time keeping it cool and will melt it down if it is used hard for long time. Getting them turned down like said above is going to be the limiting factor. For as long as it takes to switch everything down, you could just as easily swap pumps around.
Danny
If you can get it down to 250 that’s less then most of stock ones around here  but not sure on injectors my 1566 has 5/20 and .093 lines it’s been on disk and going on chisel plow this fall my thought build it and  use it
