International 504
Dwayne H
I got a 504 from a neighbor found out the tractor throwed a piston through the block it has a d188 is there any other engines that are interchangeable with it. Or does anyone out there have a useable international D188 diesel engine that you are willing to part with, thank you
6 hours ago, Dwayne H said:
Will a D239 work in place of the D188
Not in a utility as they don't have frame rails. Possibly in a Farmall 504 which does. I think and maybe someone else knows for sure that the clutch housing is the same for a  Farmall 544 and 504.
