Finally got tractor back together.
twood1954
Good luck with the pull. Hopefully your luck turns out better now
Looks good!
9 hours ago, searcyfarms said:
if its a trip plow you use, when it comes out of the ground better be ready for the throttle, clutch,  brakes as it looks a tad bit speedy?
Probably plowing,wheel harrowing, and finishing,all in the same pass with that much speed 😂
