Farmall1066 Posted August 22, 2021 Share Posted August 22, 2021 The 706 I’ve been working on for awhile might make its first attempt at starting this week. So my question is, the tractor sat for 25-30 years, the generator was rebuilt, and a new wiring harness, but I haven’t done anything with the voltage regulator yet, should I just replace it with a new one, or see if the old regulator will still do the job? And do I need to polarize the system yet? Never worked with a generator system before, the shop that rebuilt the generator claims I don’t have to polarize after the rebuild?! Quote Link to comment Share on other sites More sharing options...
searcyfarms Posted August 22, 2021 Share Posted August 22, 2021 8 minutes ago, Farmall1066 said: The 706 I’ve been working on for awhile might make its first attempt at starting this week. So my question is, the tractor sat for 25-30 years, the generator was rebuilt, and a new wiring harness, but I haven’t done anything with the voltage regulator yet, should I just replace it with a new one, or see if the old regulator will still do the job? And do I need to polarize the system yet? Never worked with a generator system before, the shop that rebuilt the generator claims I don’t have to polarize after the rebuild?! hook everything up, start it up and check the voltage at the battery while running that will tell you if its working to discharge/charge - if the gauge is working it will reveal whether or not you need to polarize it. Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 22, 2021 Share Posted August 22, 2021 Just guessing. The original Delco has probably been replaced by an Echlen. Which was still better than any thing you can buy new. It probably won't work as it is. It probably needs a good cleaning and reset. I would certainly try it before I did any thing to it. Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 22, 2021 Author Share Posted August 22, 2021 57 minutes ago, snoshoe said: Just guessing. The original Delco has probably been replaced by an Echlen. Which was still better than any thing you can buy new. It probably won't work as it is. It probably needs a good cleaning and reset. I would certainly try it before I did any thing to it. I think it’s still the Delco? It has red paint on it that looks factory? Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 23, 2021 Author Share Posted August 23, 2021 59 minutes ago, searcyfarms said: hook everything up, start it up and check the voltage at the battery while running that will tell you if its working to discharge/charge - if the gauge is working it will reveal whether or not you need to polarize it. I don’t want to fry the generator though, if something isn’t right Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted August 23, 2021 Share Posted August 23, 2021 Go ahead and polarize it before you try to start it. But don't toss it. It's likely MUCH better quality than a new one. 1 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 23, 2021 Share Posted August 23, 2021 2 hours ago, Farmall1066 said: I think it’s still the Delco? It has red paint on it that looks factory? If it's Delco. The adjusting screws will be there. You can follow instructions Ace posted on Absent Minded farmers thread. 1 Quote Link to comment Share on other sites More sharing options...
searcyfarms Posted August 23, 2021 Share Posted August 23, 2021 well maybe im just dumb and lucky, ive started up, ran, replaced parts, made sparks but never burned up a generator. One regulator over the years and odds are it was failed before I fired anything up or tried to check anything. I never checked for polarity unless the gauge read backwards. or if the wiring was so chewed up and I was afraid of a fire, nothing was hooked up before I started the tractor. I just put volt meter on the post/leads where the wiring would go to the battery and read from there. if you are worried about it, unhook the wire going to battery and fire it up that way and test your voltage out, the process for polarity is easy peasy - watch this 3 hours ago, Farmall1066 said: I don’t want to fry the generator though, if something isn’t right 1 Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 23, 2021 Share Posted August 23, 2021 11 hours ago, Farmall1066 said: I don’t want to fry the generator though, if something isn’t right Only way you're going to fry the generator in this situation is if you take it off the tractor, and put it in a cast iron pan on the stove with some canola oil... In other words, you won't. Quote This Troubleshooting Procedure (Para. 5) will describe how to tell if non charging is the fault of the Generator versus the Voltage Regulator and provide other checks (including Motor testing of the Generator) to determine why the tractor isnt charging. TROUBLESHOOTING CHARGING SYSTEMS ARE YOU SURE THE AMMETER IS WIRED CORRECT AND WORKS????? If you turn the lights or ignition on (if coil ignition not a mag) when she’s not running, the ammeter should swing over to the - discharge direction, does yours??? Are BOTH the ammeter terminals reading hot battery voltage?? They MUST !!!!!!! There’s but one wire on the ammeters Supply (from battery/starter) terminal while its other Load terminal wires to the BAT terminal on a Cutout relay or VR PLUS wires to feed loads like lights or ignition, UNLESS where a 4 terminal VR is used, and if so lights n ignition are fed from the LOAD terminal on the VR. To Polarize the Generator, first temporarily dead ground the Gens Field post to case/frame, then momentarily flash jump a wire from the Cutout Relay or VR's "BAT" terminal over to its GEN/ ARM) terminal and you ought to get a small spark. Same things accomplished by momentarily flash jumping a hot wire (BAT terminal on Cutout Relay or VR or starter post etc) direct to the Gens ARM post to get the spark. TROUBLESHOOTING A CHARGING PROBLEM IN CLASS A DELCO TYPE SYSTEMS 1) For a good working Gen to get to and charge the battery, it has to have a path usually from the Gens ARM post,,,,,,,,,,To and through the Cutout Relay (between its GEN and BAT terminals, regardless if on a VR or Relay),,,,,,,,,Up to the Load (NOT to battery) side of the Ammeter,,,,,,,,,To and through the Ammeter,,,,,,,,,,From BAT side of Ammeter to ungrounded battery terminal, often via the starter lug post. Is yours wired that way or equivalent ??? The ammeter should read hot battery voltage on BOTH terminals, does yours??? Even if an ammeter were stuck (but still continuous) as RPM increases the battery voltage should rise from 12.6 to near 14 volts and/or the lights glow brighter (half that on 6 volt systems). Have you tried that in case the ammeter isn’t working right????? 2) If the above is so, the BAT terminal on the VR or Cutout Relay MUST ALWAYS READ HOT BATTERY VOLTAGE. Does yours??? If not, the Gen cant get to and charge the battery. 3) The Gen to VR (if it has one) wiring is as follows: BAT on VR to ammeters load (NOT battery) side ARM (or GEN) on VR to Gens Armature post. FLD on VR to Gens Field post. (L) Load (if you have a 4 wire VR) up to BAT supply input terminal on switch to feed loads like lights and ignition. WIRING ON CUTOUT RELAYS: They wire BAT side to ammeters Load terminal,,,,,,GEN side to gens Armature post. On cutout relay systems, the Gens Field post is wired to the light switch where it gets a dead ground for high charge or a resistive ground for low charge. Therefore, there must be a good connection from the Gens Field post up to the switch PLUS the switch is good and it’s well grounded !!!!!!!! 4. THE GEN AND VR OR CUTOUT RELAY MUST BE WELL GROUNDED AND THE BELT GOOD N TIGHT. If any doubt, run a ground wire from the grounded battery post or clean solid frame member direct to the Gen and see what happens???????????????????????????? NOW, if the Gen and VR are grounded,,,,,all is wired correct,,,,,,,,BAT terminal on VR or Cutout Relay is HOT,,,,,,,,Belt is tight,,,,,,,,,Ammeter is good n continuous n works but she wont charge, have you had the batteries tested lately????? Is there electrolyte above all the plates and no cells have a gray or milky appearance?????? A bad battery may not accept a charge you know!!!!!!!! If the battery checks okay, proceed below to see if its a Gen or VR problem (AFTER you have insured the wiring per the above) TO DETERMINE IF ITS A GEN OR VR OR CUTOUT RELAY PROBLEM 5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR's Field post to the Field terminal on the VR, or the VR isn’t well grounded. b) IF IT’S A CUTOUT RELAY SYSTEM and she charges only if you dead ground the Field but NOT otherwise, its either a bad switch or the switch isn’t well grounded or else the wires bad or open from the Gens Field post up to the switch. INSURE THAT GOOD SWITCH GROUND AND WIRING 6. If she still don’t charge, leave the Field grounded and jump a wire across from the VR or Cutout Relays BAT terminal over to its GEN terminal (jump by passes the cutout relay) and see if she charges. If then but not otherwise, a VR's cutout relay isn’t working correct (maybe points burned/carboned) or a Cutout Relays NOT working or not wired correct. 7. With the 2 steps above, you have basically by passed the VR or Cutout relays functions, so if she still don’t charge, you're left with a bad battery or wiring or the Gen itself. 8. MOTOR TEST. You can Motor test the Gen. If its grounded and you remove the belt and apply hot battery voltage direct to its ARM Post and have the Field Post dead grounded to frame, it should motor n run well (Armature n Brushes and Commutator likely okay). Then, if you next remove the Fields ground and it speeds up some, the Fields probably good. If it passes both those tests, it should charge, and if not, it may be a wiring or battery or grounding problem. The hot battery voltage may be taken off the VR's BAT terminal or the starter post or the battery itself for this test. 9. Typical Gen problems may be the brushes are worn down or the hold down spring assemblies are stuck/corroded/dirty and arent pushing the brushes tight down against the commutator. Check those things out. Worse may be bad fields or armature etc. Air and WD 40 etc can clean and free them, the hold downs must be free n snap and hold the brushes DOWN TIGHT and they cant be worn down too low. SUMMARY: Check the wiring,,,,,the grounds,,,,,,insure BAT on VR or Relay is hot,,,,,,,check battery (maybe load tested and Specific Gravity checked),,,,,,,,,good tight belt,,,,,,,insure ammeter is continuous (BOTH sides HOT),,,,,,see if battery voltage rises above 12.6 (half that for 6 volt system) and/or light glow brighter,,,,,,,,,do the Field and cutout relay VR by pass checks,,,,,,,,insure the Gens brushes arent worn down and the hold down springs are free n clean and push the brushes down tight,,,,,,,,,,,check the connections,,,,,,,,,try the Gen Motor Test to see if its good. You may just have a bad battery or bad ground or connection if the Gen and VR or relay are okay. Good Luck n God Bless, let us all know. John T Nordhoff in Indiana, retired Electrical Engineer 1 1 Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted August 23, 2021 Share Posted August 23, 2021 8 hours ago, searcyfarms said: well maybe im just dumb and lucky, ive started up, ran, replaced parts, made sparks but never burned up a generator. One regulator over the years and odds are it was failed before I fired anything up or tried to check anything. I never checked for polarity unless the gauge read backwards. or if the wiring was so chewed up and I was afraid of a fire, nothing was hooked up before I started the tractor. I just put volt meter on the post/leads where the wiring would go to the battery and read from there. if you are worried about it, unhook the wire going to battery and fire it up that way and test your voltage out, the process for polarity is easy peasy - watch this Seems like every time I had the generator or even the battery unhooked on my 706, I had to repolarize the regulator. Thats one off the main reasons I went to an alternator on that particular tractor. But other tractors, had stuff unhooked, never had to polarize them. Sometimes stuff is funny like that. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 23, 2021 Share Posted August 23, 2021 By the way, you can repolarize as much as you want. It won't hurt anything if you do it correctly. 1 Quote Link to comment Share on other sites More sharing options...
Farmall1066 Posted August 23, 2021 Author Share Posted August 23, 2021 Still the delco in it Quote Link to comment Share on other sites More sharing options...
