BobinIL Posted August 22, 2021 Share Posted August 22, 2021 I have a real nice barn find 1963 706D with 2800 hours working tach. I want to show this tractor off but want to be careful not to blow the head gasket. It has a 2 pt hitch and I would like to plow with it. I am thinking a 540 plow either 4-14 or 3-16 would be a good match. I never use ether on it. I put new glow plugs in it and it starts perfectly. It currently has 16.9-38 back tires on it that need replaced. Tractor data says it should have 15.5-38 on it. which would be best for a show and plowing demonstration tractor? Quote Link to comment Share on other sites More sharing options...
DT Fan Posted August 22, 2021 Share Posted August 22, 2021 I'm kind of a 'big' rubber fan, would stay with the 16'9's!! Quote Link to comment Share on other sites More sharing options...
plowboy64 Posted August 22, 2021 Share Posted August 22, 2021 I think we need pictures to decide I'm with the bigger is better crowd Quote Link to comment Share on other sites More sharing options...
BobinIL Posted August 22, 2021 Author Share Posted August 22, 2021 3 Quote Link to comment Share on other sites More sharing options...
ny bill o Posted August 22, 2021 Share Posted August 22, 2021 I vote for the 16.9s, especially if you will be plowing with it. FWIW, if you run across 14.9x38, they would stand a little higher than the 15.5s. Probably 14.9s will be harder to find. You might be surprised what the tires in the picture will pull with the addition of a couple pairs of wheel weights. 1 Quote Link to comment Share on other sites More sharing options...
BobinIL Posted August 22, 2021 Author Share Posted August 22, 2021 how would 9.5-15 fronts look instead of the 7.00-16?? any opinions on plow size?? Quote Link to comment Share on other sites More sharing options...
TripleFangus Posted August 22, 2021 Share Posted August 22, 2021 Here’s how 18.4’s and 11.00’s look on one. 6 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted August 22, 2021 Share Posted August 22, 2021 Here's a pic of my 826 with 9.5LX15's. It should handle 3-16's or 4-14's fine I would think. Depends on what you can find. 1 Quote Link to comment Share on other sites More sharing options...
TP from Central PA Posted August 22, 2021 Share Posted August 22, 2021 Pulled a 4-14 540 with one here............Worked ok.................3-16 might be better depending on soil types. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 22, 2021 Share Posted August 22, 2021 16.9x38's are expensive for their size, almost more expensive than 18.4's. To me, 15.5's will be too small and 18.4's look way too big on a 706. 16.9's or 420/85R38 would be my choice even though they are not the best value. It's pretty likely that your rims are 14" wide or less and would put quite a squeeze on 18.4x38's. 1 Quote Link to comment Share on other sites More sharing options...
FarmallTom Posted August 23, 2021 Share Posted August 23, 2021 16.9's are a very nice size for a 706. 15.5.s will look dinky on a tractor that size. This is my dad, on my 706 with 16'9's, pulling a 4-14's #540: -FT 4 1 Quote Link to comment Share on other sites More sharing options...
dm17529 Posted August 23, 2021 Share Posted August 23, 2021 I went to 16.9 x 34's on my 706LPG from the worn out 18.4 x 34's which were removed. I would not go smaller than the 16.9's. 1 Quote Link to comment Share on other sites More sharing options...
dm17529 Posted August 23, 2021 Share Posted August 23, 2021 In addition, in my case, the 16.9's were cheaper than the 18.4's and I pull a Deere 4 x 16" semi-mounted plow in sandy loam soil with no problem. Quote Link to comment Share on other sites More sharing options...
Mr. Plow Posted August 23, 2021 Share Posted August 23, 2021 Our 706 has 15.5's......looks tiny......get 16.9s Quote Link to comment Share on other sites More sharing options...
searcyfarms Posted August 24, 2021 Share Posted August 24, 2021 21 hours ago, FarmallTom said: 16.9's are a very nice size for a 706. 15.5.s will look dinky on a tractor that size. This is my dad, on my 706 with 16'9's, pulling a 4-14's #540: -FT man my 706 with german must be shot or something wrong, if it was pulling a 4 bottom like that it would be letting a lot of black smoke out the exhaust - your dads doenst even smoke at all. Quote Link to comment Share on other sites More sharing options...
Missouri Mule Posted August 25, 2021 Share Posted August 25, 2021 On 8/22/2021 at 10:21 AM, BobinIL said: how would 9.5-15 fronts look instead of the 7.00-16?? any opinions on plow size?? I went from 7.00-16's to 9.5-15's on my 656 and it made it look soooooo much better IMO. I went with wider rims too so they balloon out more. I have a set of 4-16's I pull and I would think a set of 4-14's would be a good match for your tractor and not pull too hard. This is a question that comes up alot here. In my soil I can pull a whole bottom less than others say in better soil. It varies that much. Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted August 25, 2021 Share Posted August 25, 2021 Plowing is just like that....John Deere (the guy) did not invent the plow as is so often stated. He just recreated the plow using a steel that would shine up - because the cast metal plows of the time would not work in heavy clay midwest soils. The same HP that pulls a 6-16 bottom in really sandy soils, may only pull 4-12 in hard clay sod. Quote Link to comment Share on other sites More sharing options...
BobinIL Posted August 26, 2021 Author Share Posted August 26, 2021 I agree watching the guys plowing at the 2019 HCOP (dry hard ground) those tractors were struggling. I want to be able to pull easy in any conditions and not damage a 50+ year old tractor Quote Link to comment Share on other sites More sharing options...
FarmallTom Posted August 26, 2021 Share Posted August 26, 2021 So - I posted the video of my 706 German pulling the 4-14's above but, in fairness, I realize that the D-310 is a step up from the D-282. Here's the 560D (also D-282 diesel) that I owned previously, pulling the same plow in 2011 in some fairly hard going at a plow day. PS: I wouldn't worry about blowing a head gasket unless you're planning to turbo it. It can happen, yes, but whether or not you pull a plow isn't likely to determine whether or not that will happen. -FT Quote Link to comment Share on other sites More sharing options...
billonthefarm Posted August 27, 2021 Share Posted August 27, 2021 This 706 came with 16.9x38’s and 7.50x16’s. The fronts are now 10.00x16 but still has 16.9x38. Quote Link to comment Share on other sites More sharing options...
acem Posted August 27, 2021 Share Posted August 27, 2021 Some of the cheap imported 18.4x38 are so undersized they would be right on a 706... Quote Link to comment Share on other sites More sharing options...
885 Posted August 27, 2021 Share Posted August 27, 2021 On 8/25/2021 at 1:02 PM, Jeff-C-IL said: Plowing is just like that....John Deere (the guy) did not invent the plow as is so often stated. He just recreated the plow using a steel that would shine up - because the cast metal plows of the time would not work in heavy clay midwest soils. The same HP that pulls a 6-16 bottom in really sandy soils, may only pull 4-12 in hard clay sod. I know that all too well. Around here in our Rocky red clay I tried pulling a 3-18 with my 282 706 and it didn't go so well. Here a 3-14 would be a pretty good match Quote Link to comment Share on other sites More sharing options...
