TroyDairy Posted August 21, 2021 Share Posted August 21, 2021 1 hour ago, nomorejohndeere said: someone else with no clue ie..case IH didn't make trucks didn't realize your thread was so serious or considered so special He is "special" trust me.😂😂😂 And i figured this was a Biden post by title. Quote Link to comment Share on other sites More sharing options...
TractormanMike.mb Posted August 21, 2021 Share Posted August 21, 2021 3 hours ago, Farmall1066 said: That’s just a 1066 black stripe, there’s no hydraulic dip stick tube or dip stick in the rear of the tractor, that’s in the 66 location. I’m guessing the 2nd 6 in 1066 got messed up a little, or not stamped correctly, so it’s hard to tell if it’s a 6 or 8?! IF this tractor was in fact a 1066 and at sometime in its life something happened to it and a rear half of a 1086 was swapped out to it the top cover for the rear housing would have to be changed over also correct??? Actually, both rear covers would have to be changed or you wouldn't be able to add or check the oil level. Somebody correct me if I'm wrong. Quote Link to comment Share on other sites More sharing options...
jass1660 Posted August 21, 2021 Author Share Posted August 21, 2021 1 hour ago, TroyDairy said: He is "special" trust me.😂😂😂 And i figured this was a Biden post by title. I’d have to be to travel dam near to Canada to see a guy like you….🤣🤣 1 Quote Link to comment Share on other sites More sharing options...
Binderoid Posted August 23, 2021 Share Posted August 23, 2021 That ad wasn’t so long. All it contained to my eyes was , think, seemed, good, couple, at times, what I’m told, I’ll send you the part when it comes. For the visuals, all I saw was a lot of red paint bleeding through the black. This was a tack used by unscrupulous Allis-Chalmers owners to hide the less reliable nature of the brown bellies. Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 23, 2021 Share Posted August 23, 2021 All I have to say is if this guy believes it's a 1086 he isn't very bright and does not listen well. 1 Quote Link to comment Share on other sites More sharing options...
234-IA Posted August 23, 2021 Share Posted August 23, 2021 I suppose the guy just doesn't want to admit he got took by the dealer 1 Quote Link to comment Share on other sites More sharing options...
806Jordy Posted August 23, 2021 Share Posted August 23, 2021 I bet its quite the horse on that tedder no matter what it is! Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted August 24, 2021 Share Posted August 24, 2021 I didn't realize case IH. Made a 1086?? 1 Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 24, 2021 Share Posted August 24, 2021 I politely asked him to send more photos and he did. It is definitely a 1066, true black stripe. Came with a cab, still has the cab floor plates. the fenders are mounted to the rear cab mounts. The complete serial number is 2610178U059671 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted August 24, 2021 Share Posted August 24, 2021 Wow,I completely missed those cab mount bracket/fender adapters. I had noted the 66 deluxe cab paint fade on the hoods, the cab style insulation around the gauges and the trim ring for the boot around the brake pedals. Did he relist it as a BS1066 yet? Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 24, 2021 Share Posted August 24, 2021 5 minutes ago, stronger800 said: Wow,I completely missed those cab mount bracket/fender adapters. I had noted the 66 deluxe cab paint fade on the hoods, the cab style insulation around the gauges and the trim ring for the boot around the brake pedals. Did he relist it as a BS1066 yet? i just finished e-mailing him with my final opinion and description right before I posted here. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted August 24, 2021 Share Posted August 24, 2021 8 hours ago, Maynard said: i just finished e-mailing him with my final opinion and description right before I posted here. Were you able to convince him? He seemed to have his mind pretty well made up, and I can't imagine that one more faceless "know it all" sending him anonymous emails about how wrong he is would change his opinion. Quote Link to comment Share on other sites More sharing options...
stronger800 Posted August 24, 2021 Share Posted August 24, 2021 All I know is if it was listed as a bs1066, here in ny, even looking like that, he’d have sold it already 2 Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 24, 2021 Share Posted August 24, 2021 21 minutes ago, Matt Kirsch said: Were you able to convince him? He seemed to have his mind pretty well made up, and I can't imagine that one more faceless "know it all" sending him anonymous emails about how wrong he is would change his opinion. I didn’t just up and tell him he was wrong. I asked for more pictures of specific areas of the tractor then explained to him what I saw, including that 1086 series serial numbers never went as high as the number on that tag. I started the conversation telling him that I had worked at IH and CaseIH dealerships since January of 1975. 2 Quote Link to comment Share on other sites More sharing options...
Maynard Posted August 24, 2021 Share Posted August 24, 2021 4 hours ago, Matt Kirsch said: Were you able to convince him? He seemed to have his mind pretty well made up, and I can't imagine that one more faceless "know it all" sending him anonymous emails about how wrong he is would change his opinion. 3 hours ago, stronger800 said: All I know is if it was listed as a bs1066, here in ny, even looking like that, he’d have sold it already Yes he has now changed it to 1066 black stripe. 3 Quote Link to comment Share on other sites More sharing options...
jass1660 Posted August 24, 2021 Author Share Posted August 24, 2021 38 minutes ago, Maynard said: Yes he has now changed it to 1066 black stripe. And he even gave you some anonymous compliments. 1 Quote Link to comment Share on other sites More sharing options...
Farmall Doctor Posted August 24, 2021 Share Posted August 24, 2021 6 hours ago, Maynard said: Yes he has now changed it to 1066 black stripe. You have done your good deed for the day! 1 1 Quote Link to comment Share on other sites More sharing options...
dannyredfan Posted August 24, 2021 Share Posted August 24, 2021 Good job, sounds like you took a good approach and he listened. Iam just glade It’s not closer. Lol. I have a soft spot for misfits and fence rows finds. 😊 2 Quote Link to comment Share on other sites More sharing options...
stronger800 Posted August 25, 2021 Share Posted August 25, 2021 I dare speculate that a good pressure washer would probably take that black paint of the chassis. somebody let us know if the listing goes away, implying it was sold. Quote Link to comment Share on other sites More sharing options...
