88power Posted August 19, 2021 Share Posted August 19, 2021 Kept having problems with over filling or they were afraid to over fill and not put enough in and the low coolant light would flash I found these at advance auto,had to remove the ether despencer but we never used them anyway, you'll also see my custom aux condenser mounting bracket I'm trying out and please forgive my spill 1 Quote Link to comment Share on other sites More sharing options...
searcyfarms Posted August 20, 2021 Share Posted August 20, 2021 thats an interesting AC Condensor mine is not like that in my 5088, is yours not keeping cool? or you just hate cleaning it and the radiator out so often? 4 hours ago, 88power said: Kept having problems with over filling or they were afraid to over fill and not put enough in and the low coolant light would flash I found these at advance auto,had to remove the ether despencer but we never used them anyway, you'll also see my custom aux condenser mounting bracket I'm trying out and please forgive my spill Quote Link to comment Share on other sites More sharing options...
88power Posted August 20, 2021 Author Share Posted August 20, 2021 That's a add on condenser the factory one is still on the bottom, this has solved a lot of our a/c problems wether it be pressures or keeping the cab cool in general. Last week we had some 90 95 degree days and the guys said they never used purge and only ran high to cool the cab down after lunch Quote Link to comment Share on other sites More sharing options...
tractorholic Posted August 20, 2021 Share Posted August 20, 2021 That tank looks like a good idea! There is really a fine line between the low level light flashing and having too much coolant in the radiator and then it boils over. 1 Quote Link to comment Share on other sites More sharing options...
88power Posted August 20, 2021 Author Share Posted August 20, 2021 8 hours ago, tractorholic said: That tank looks like a good idea! There is really a fine line between the low level light flashing and having too much coolant in the radiator and then it boils over. I got the idea from here, one of the techs (forgive me i have forgotten who) was talking about putting one of these on back when they where new or close to it. But it does help I've done all but two now i'm just waiting for them to rotate thru the shop it takes at most 30 mins to throw one on Quote Link to comment Share on other sites More sharing options...
acem Posted August 21, 2021 Share Posted August 21, 2021 They should have had one when new. 1 Quote Link to comment Share on other sites More sharing options...
redpower123 Posted August 25, 2021 Share Posted August 25, 2021 Where is your primary air filter Quote Link to comment Share on other sites More sharing options...
IHC5488 Posted August 26, 2021 Share Posted August 26, 2021 1 hour ago, redpower123 said: Where is your primary air filter It's there....looks like a shadow but it is the black rubber gasket....the clamp wouldn't be tight if it was missing Quote Link to comment Share on other sites More sharing options...
jass1660 Posted August 26, 2021 Share Posted August 26, 2021 3 hours ago, redpower123 said: Where is your primary air filter They don’t have a cover like the older series did. Quote Link to comment Share on other sites More sharing options...
Mike56073 Posted August 26, 2021 Share Posted August 26, 2021 Do you have a part number for that tank? Also, did you change the radiator cap? Quote Link to comment Share on other sites More sharing options...
88power Posted August 27, 2021 Author Share Posted August 27, 2021 On 8/26/2021 at 8:19 AM, Mike56073 said: Do you have a part number for that tank? Also, did you change the radiator cap? Dorman 603-001 and I didn't change the cap 1 Quote Link to comment Share on other sites More sharing options...
