Jesse in WI Posted August 17, 2021 Share Posted August 17, 2021 I have a 311 pull type brush mower that could use some new parts. I could use a couple clutch facings (474599R3) and the front hanger bearing on the driveline (ST669). I looked these up and was a little shocked by the prices. The friction discs for the clutch are listed at $110 each and the bearing is listed at $237. Is there any way to find these parts aftermarket? If I replaced these parts and put a new set of blades ($500) I'm going to have almost $1000 in just a couple parts on a machine that's barely worth that much. Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted August 17, 2021 Share Posted August 17, 2021 Our 111 3 point mower has a bad stump jumper. We have talked about removing it and returning it to service, but it is still waiting in the shed. With the damage, it has a bad vibration due to poor balance. Quote Link to comment Share on other sites More sharing options...
Moodnacreek Posted August 18, 2021 Share Posted August 18, 2021 23 hours ago, Jesse in WI said: I have a 311 pull type brush mower that could use some new parts. I could use a couple clutch facings (474599R3) and the front hanger bearing on the driveline (ST669). I looked these up and was a little shocked by the prices. The friction discs for the clutch are listed at $110 each and the bearing is listed at $237. Is there any way to find these parts aftermarket? If I replaced these parts and put a new set of blades ($500) I'm going to have almost $1000 in just a couple parts on a machine that's barely worth that much. Try to find a number on the bearing and search for that. On the frictions is there any thing they can be matched up to? A clutch/brake relining shop [hard shop to find] would have something. Quote Link to comment Share on other sites More sharing options...
