Can u identify model of td9 from attached serial number
You may be right they started over in 1959 with the introduction of the 92 series, which utilized the 6 Cyl direct start engine.
Definitely a TD-9 or 9A as the air cleaner is between your legs.  the later models (91 and 92 series ) moved the air cleaner under the hood so your crawler could easily be from 1940.
