Leaking hydraulic cylinder for blade lift on td15c
33 minutes ago, rodhergott said:
Cylinder is leaking.   I’ve ordered seal kit.   The cylinder looks really heavy to remove   Can I just remove the insides and take to hydraulic shop
Of course! Just block the barrel securely and have some help. Going to have to lift the rod over the blade while oil pouring everywhere. Watch out for stepping on oily parts so you don’t slip and hurt your self
You might want to remove the tube portion for reassembly of the cyl . Perfect alignment is the trick for assembly without damaging the piston seal. Good Luck!
