I already know the answer, but
Farmall1066
2 minutes ago, Nebraska1206 said:
It would be expensive, but, if you have a reputable machine shop that can weld up a crankshaft, you could take a 361 crankshaft, have them weld the rod journals & offset grind them to increase the stroke to 407 specs.  It would be expensive & time consuming, but, an option since there are likely more 361 crankshafts to be found.  You'd want one that's standard/standard on the journals, since the main journals need to be turned down to true them up after all the welding on the crankshaft.
That does sound expensive!!! I might have one on the hook?! Dirtboyz might have one for me?!🤞🏻🤞🏻🤞🏻🤞🏻🤞🏻
