TD15c cylinder for blade lift leaking
Take it apart and take the gland and the piston to a hydraulic shop and let them match up the pieces. Too many blade configurations and cylinders would make nailing down the correct kit by part number an iffy proposition just trying to use tractor serial number.  By time you I D the blade and cylinders you could have it fixed and back on the machine.
