rodhergott Posted August 9, 2021 Share Posted August 9, 2021 I have to pump grease in every 4 hours to tighten the track. How big of a job is it to repair/replace the seals that are likely leaking. I would hire a pro Link to comment Share on other sites More sharing options...
DWF Posted August 9, 2021 Share Posted August 9, 2021 You have to break the track and then slide the idler out enough to get the cylinder out, hopefully it's not pitted to bad. DWF Link to comment Share on other sites More sharing options...
rodhergott Posted August 9, 2021 Author Share Posted August 9, 2021 Sounds like big job. Maybe I’ll buy more grease. How many hours do u estimate Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted August 9, 2021 Share Posted August 9, 2021 I’m sure it would be difficult to estimate the time required very accurately. A machine this age, you never know what you might find. A lot will depend on how hard the track is to separate. Has the master link been butchered by the previous owner(s)? Will whoever does the repair use a pin press or drive the pin out the hard way? I can’t imagine what it would take to break the track on mine. The master link has been welded and rewelded and then rewelded again just for good measure. I plan to just torch my link in half and then replace it when I can get around to it. I’ve had my own ongoing project for awhile and track work is expensive. Check availability on all the parts before you do anything drastic. Link to comment Share on other sites More sharing options...
just Dave Posted August 10, 2021 Share Posted August 10, 2021 You might want to look into a much heavier grease, pending repair. There is also a sealing wax product used to seal large gas valves after they have been cycled. It does not harm a precision gas valve and cleans up easy enough when rebuilding. You should be able to find options at an industrial supply house. Link to comment Share on other sites More sharing options...
rodhergott Posted August 10, 2021 Author Share Posted August 10, 2021 Very useful suggestions Link to comment Share on other sites More sharing options...
hardtail Posted August 10, 2021 Share Posted August 10, 2021 You must be using this quite a bit Rod? Link to comment Share on other sites More sharing options...
rodhergott Posted August 10, 2021 Author Share Posted August 10, 2021 Do u mean the site. Oh yea for sure. I find everyone friendly and helpful Link to comment Share on other sites More sharing options...
hardtail Posted August 11, 2021 Share Posted August 11, 2021 No I mean the 15, you must be brushing Millet clean...lol Link to comment Share on other sites More sharing options...
rodhergott Posted August 11, 2021 Author Share Posted August 11, 2021 Yes I realized what u meant later. I’ve done about 15 acres. I started last summer with my td9 but finishing up with td15c. Td9 didn’t have quite enough to push roots out Link to comment Share on other sites More sharing options...
Weapon Posted August 11, 2021 Share Posted August 11, 2021 Back in the day on the older machines guys would pump up the adjuster, measure the distance between idler yoke and piston cylinder, cut and split a section of pipe to fit over and clamp together. Not rite nor pretty but got them thru. Just my thoughts, John Link to comment Share on other sites More sharing options...
rodhergott Posted August 11, 2021 Author Share Posted August 11, 2021 Sounds a little bit less ke using bale wire for other fixes. But I can see on flatter surfaces that it would work Link to comment Share on other sites More sharing options...
rodhergott Posted August 15, 2021 Author Share Posted August 15, 2021 I replaced the valve with the grease zerk. On the first go around as I filled it with grease, grease came out between the valve and the body of the tightened. I checked that I had tightened it enough and I think I did so I removed it and put an oring on the valve and reinstalled it. I don’t think it leaked grease this time. Any thoughts on this. The manual doesn’t show an o ring Link to comment Share on other sites More sharing options...
just Dave Posted August 17, 2021 Share Posted August 17, 2021 Any thing can be improved if it sealed it itis a good thing. My 150 had a stuck adjuster when i bought it. I hard piped a porta-power pump to it and was able to break it loose, then followed the oil with grease. I havn't had any more trouble out of it. Link to comment Share on other sites More sharing options...
Rawleigh99 Posted August 17, 2021 Share Posted August 17, 2021 If it works, run it! Link to comment Share on other sites More sharing options...
