International 240
I replaced my steering wheel on the 240 utility. The steering shaft was very loose in the tube. I seen that there was just a plastic bushing. I had to do a redneck engineering. I put zip ties down the tube. Started at the 6 o'clock position. Moving the shaft to get clearance on each side as I went. Believe it or not it works like a champ!
