planejeff Posted August 6, 2021 Share Posted August 6, 2021 Picking up an International 300 utility tomorrow! Hopefully the engine and transmission are in good shape! The sheet metal is in great shape. 5 Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 7, 2021 Share Posted August 7, 2021 Manual steering and no loader. Looks like a plus to me. 2 1 Quote Link to comment Share on other sites More sharing options...
TN Hillbilly Posted August 7, 2021 Share Posted August 7, 2021 Is there other sheet metal to go around the tank? Never seen a 300U propane. Quote Link to comment Share on other sites More sharing options...
planejeff Posted August 8, 2021 Author Share Posted August 8, 2021 3 hours ago, TN Hillbilly said: Is there other sheet metal to go around the tank? Never seen a 300U propane. Yes has all the sheet metal with no dents! 3 Quote Link to comment Share on other sites More sharing options...
bitty Posted August 8, 2021 Share Posted August 8, 2021 11 hours ago, planejeff said: Yes has all the sheet metal with no dents! That's quite the fairly rare find unless they were common down south. I see it's TA delete so it probably was a southern tractor now or at some point 1 1 Quote Link to comment Share on other sites More sharing options...
Sledgehammer Posted August 8, 2021 Share Posted August 8, 2021 That is different for sure. The pics make it look like it would be hard to see to drive it almost. Can’t be a lot of those around. Good luck with the project. 2 1 Quote Link to comment Share on other sites More sharing options...
planejeff Posted October 24, 2021 Author Share Posted October 24, 2021 Update on the progress of the international 300. Torn down the engine. Replaced sleeves. Replaced the flat head piston with fire crater pistons. Had the crankshaft turned. Replaced the camshaft and gear. Had to get new valves manufactured at Manley sales. ( Propane valves were longer than gas valves.) Got brake parts and clutch from Ebay. Website's that are great to find parts from. Tractorpartsasap.com Steiner.com Messick.com Currently putting the engine back together and mounting to the rest of the tractor. The reason the crankshaft and camshaft were in bad shape was water sat in the engine. I assumed that it wouldn't have that issue since the propane tank is over the engine plus the exhaust goes under the tractor. I'm guessing that the hurricane may have submerged the tractor for a few days. As the tractor sat since Hurricane Harvey caused the problems. Hope to have a video of it running soon! 1 Quote Link to comment Share on other sites More sharing options...
Tonyinca Posted October 24, 2021 Share Posted October 24, 2021 I believe you have a jewel there ! she does not look abused , being your doing engine work , you could install a TA if so desired . I have a gasser 300U only because that’s what my Dad had but if I would of picked one it would of been LP these are fun tractors to operate and lot of power . Good luck with it ! tony 3 Quote Link to comment Share on other sites More sharing options...
planejeff Posted October 24, 2021 Author Share Posted October 24, 2021 20 minutes ago, Tonyinca said: I believe you have a jewel there ! she does not look abused , being your doing engine work , you could install a TA if so desired . I have a gasser 300U only because that’s what my Dad had but if I would of picked one it would of been LP these are fun tractors to operate and lot of power . Good luck with it ! tony 20 minutes ago, Tonyinca said: I believe you have a jewel there ! she does not look abused , being your doing engine work , you could install a TA if so desired . I have a gasser 300U only because that’s what my Dad had but if I would of picked one it would of been LP these are fun tractors to operate and lot of power . Good luck with it ! tony Thanks! That is a great looking tractor and blade! The front weights are rare from what I've seen. What is the tire size you have? The one I have has 12.4x28. I don't know if that was standard from factory. The big plus for the 300 than the 240 is the hp and weight. The underslung exhaust makes it easier to get under trees also! Quote Link to comment Share on other sites More sharing options...
Tonyinca Posted October 25, 2021 Share Posted October 25, 2021 6 hours ago, planejeff said: Thanks! That is a great looking tractor and blade! The front weights are rare from what I've seen. What is the tire size you have? The one I have has 12.4x28. I don't know if that was standard from factory. The big plus for the 300 than the 240 is the hp and weight. The underslung exhaust makes it easier to get under trees also! Rears on mine are 14.9x28 . Factory were 12.4 's , Being I had to buy new rims ,I went for the wider one's. Your right on the underslung exhaust . The frame weights are harder to find but they are available ,They show up every so often on e bay or market pages Tony 1 Quote Link to comment Share on other sites More sharing options...
jeeper61 Posted October 25, 2021 Share Posted October 25, 2021 Good find Any idea what the brackets on the fender are for possibly a sun shade? Quote Link to comment Share on other sites More sharing options...
Tonyinca Posted October 25, 2021 Share Posted October 25, 2021 3 hours ago, jeeper61 said: Good find Any idea what the brackets on the fender are for possibly a sun shade? Sun Shade brackets , perhaps modified as they appear longer then usual. Tony 1 Quote Link to comment Share on other sites More sharing options...
planejeff Posted November 5, 2021 Author Share Posted November 5, 2021 It's alive! 5 Quote Link to comment Share on other sites More sharing options...
Tonyinca Posted November 5, 2021 Share Posted November 5, 2021 Looks great ! You sure did a number on that paint bringing it back to life. Congratulations, Hope with her running that you do not have many mechanical encounters Tony Quote Link to comment Share on other sites More sharing options...
planejeff Posted November 5, 2021 Author Share Posted November 5, 2021 6 hours ago, Tonyinca said: Looks great ! You sure did a number on that paint bringing it back to life. Congratulations, Hope with her running that you do not have many mechanical encounters Tony Thanks. We had some adjustments to make but for the most part it's good little tractor. Waiting on tires now going with 12s. It's now time to start the real winter schedule project an Oliver Super 77 (Been in the family for over 50 years!) 1 Quote Link to comment Share on other sites More sharing options...
planejeff Posted November 21, 2021 Author Share Posted November 21, 2021 We had to replace the regulator. Now it runs well! One of the two shutoff valves and vapor valve are leaking. All of part numbers that are in the parts manual are not found on the internet. I going to take all the valves off and go to a propane parts dealer. Hopefully match up the valves. There is a lot of valves online but they mostly go by weight not the outlet sizes! Have a great day everyone! Quote Link to comment Share on other sites More sharing options...
mmi Posted November 21, 2021 Share Posted November 21, 2021 IIRC doc e had some sources for some parts Quote Link to comment Share on other sites More sharing options...
planejeff Posted November 23, 2021 Author Share Posted November 23, 2021 On 11/21/2021 at 1:20 PM, mmi said: IIRC doc e had some sources for some parts Is that a business? Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted November 23, 2021 Share Posted November 23, 2021 14 hours ago, planejeff said: Is that a business? Member here. Dr Evil? 1 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 23, 2021 Share Posted November 23, 2021 2 hours ago, iowaboy1965 said: Member here. Dr Evil? That would be my guess too. Fascinating guy, hope to meet him in person some day! 1 Quote Link to comment Share on other sites More sharing options...
