Engine Coolig fan swap on 2388
My brother was running my 2388 finishing up Corn a couple years ago,and the metal engine cooling fan went to pieces and involved the radiator and the air to air box.
we replaced the components and added the plastic cooling fan. I hired the work done but was sure we didn't replace the fan shroud.
Now I have purchased another late model 2388 that still has the steel/aluminum fan. Parts man says some have to have a different fan shroud, and motor mounts. Would this be for earlier 2388's, can anyone say. Shroud is almost 3 times what the fan is cost wise.
also if the shroud doesn't need changed can the metal blade be removed and plastic one installed without tearing things apart much. New bearing on fan mount?
TIA
