K&N Air Filters, Good or Bad?
I am using one backwards (vacuum on the outside instead of the inside) inside of the 450 oil bath housing . I like the oil bath but when the starter doesn't wheel it over good enough it rotates backwards a little bit. This pukes a little oil in the glass precleaner jar all over the 1/64 JD 720 inside of the jar. This is going to run maybe long enough to burn 20 gallon of fuel per year. Hoping this will filtrate well enough.
You will be fine
Get some of this filter foam and wrap the filter that will prevent the spit back
UNI is the other dirt bike filter from the 70s as with a K&N they have to be oiled when used as a primary filter
I just use this foam as a pre filter I put it over the opening in the air box dry with a piece of screen to keep the mice out
And it keeps all trash out of the dirty side of the air box
I put some of this on the heater intake on the tractor cab to to keep the dust down some
It comes in squares
15 hours ago, jass1660 said:
OEM vehicles aren’t sold by the engineers they’re sold by the accountants. All they want to sell them with is the bare minimum required. They won’t upgrade filters or anything else, planned obselence.
Maybe, but K&N is no upgrade. As referenced above the MAF sensor needs to be spotless to work and no way will a K&N keep the dirt off it. I've noticed my PUs and wife's Yukons have a clog indicator and running on the street they never show needing service.
All this anti K&N is news to me, my last pickup F-250 ran 225,000 miles before I traded it in Never had an issue  always got the same millage and it ran fine and 70% farm miles
I must just be lucky
Would think K&N would be out of business if it was that bad
Every tractor at the pulls has one within 12" of the carburetor
Ye olde 2nd gen Cummins had the kn filter for around 200,000 and 400,000 total and when the head gasket blew guts still looked new for what's it's worth.  And I live on a fine dust road
Anyone remember the name of the aftermarket oil filtration system for large diesel engines it was a large canister I think it was a spin filter with a moisture cook off chamber?
There are several bypass oil filtration systems on the market. OPS, Harvard are a couple.
Franz filters, metal cover had a locking buckle with a roll of select your own toilet paper.  Every weekend near the automotive area at Kamart there would be a guy with some old car  (or F250 Ford) demonstrating how great it worked.  Came with a life time warrantee. Appears to have worked so well that they went out of business. Probably Wix bought them out just to get rid of the competition.
  • 3 weeks later...
They make power , thats why  you see them at the pulls.  They flow very good, but a clean K&N doesn't filter well.  A dirty one filters much better.
I will go out on a limb here. I think they are made for one purpose, sold for another, if you are tractor pulling, truck pulling, maybe even some kind of hopped up street racing you want flow, filtration and longevity maybe are less important for myriad reasons, probably is a big improvement. if you are looking for longevity and excellent filtration I don't see how they are an improvement, when I look at the junk my air box filters out just from gravity, before it ever reaches the filter and then the difference between the inside of the intake and the dirty side of the air box, I don't believe a K&N open style filter is going to pass my white glove test of the inside of my intake tube. I also don't think it is going to make a difference in a vehicle that isn't set up to accept increased air flow. personally if I get better filtration and a minuscule less amount of power or poorer economy it is still a win. those factory paper filters do a tremendous job of doing what they are supposed to do, which is to filter air. If I don't have to fight with a dealer about warranty in the first 100K and don't have to make unnecessary expensive repairs in the next 100K  of my miserable dirt road driving the truck is pretty well spanked by then.. and I haven't had to spend my time washing filters, and I have never dusted an engine.
I understand your Point's
I will say I have run them for years and up to 220,000 miles and clean them every 5000 miles and have not lost an engine on my last 5  trucks
Since modern engines have a mass airflow sensor and adjust the mixture according to that, a filter that may be less restrictive won't give any more nor less mpg. Might as well have the cleanest air.
3.13% separates the the bottom from the top.
Ever notice they don't state their test uncertainty?
It might be larger than 3%
Here's the protocol. The methodology is quite clear and unambiguous: https://www.iso.org/obp/ui/#iso:std:iso:5011:ed-4:v1:en
Even if the paper filters aren't separated by much, not enough to make the brand choice significant,  it clearly shows the K&N the least effective.
The point being that K&N advocates tend to state their cars run more economically with the expensive filter they bought and of course if one spends money on something one wants it to meet its claims. In the case of a stock engine installation it just cannot.  I certainly can see using one on equipment that's not computer controlled, especially if the alternative is nothing.
That is the ISO standard they are testing to.
Where is their uncertainty calculation for all the test instruments they used and there impact on their tests? What is the sample size of their test?
 Anyway as I have and others have stated it is easier to use paper filters and they provide better filtration
In some applications i.e. all out horse power the slight flow increase is worth the the trade offs
Item 4 prescribes the test instrument standards and accuracy.
As with everything ISO you need to "buy in" to get a copy
These uncertainty calculations are instrument specific because they can vary from brand to brand
I happen to work for a ISO 17025 accredited testing lab so I know all about it.
Cool!
What are you testing?
Having owned an avionics shop keeping all of our test equipment calibrated and traceable as required was an expensive proposition. Aircraft navigation, communication and air-data systems (altimetry, speed, etc.)
We are  accredited for calibration of measuring robots our best uncertainty is sub micron
So just about every part in a jet engine is dimensionally verified on one of our systems
Actually just about every manufactured item is dimensionally verified on one of our or Zeiss's systems
https://www.hexagonmi.com/en-US/about-us/about-hexagon-manufacturing-intelligence/what-we-do/metrology
