Who is a fan of Double Ds
Big Bud guy
It sounds weird when both engines are not in phase.
But someone did a very nice job putting those two together.
those are one of the best sounding J.D'S   .always did like the sound of them even in the evening could her them for miles in the field. i bet those 2 will out pull the 830.
It would out pull any tractor that size and bigger.  The original owner pulled two 4 bottom plows and a 26ft chisel.
1 minute ago, TP from Central PA said:
Simple guy thought it was 2 D15's with roto balers?????????????????
Nah.  If I was going to post a D series the only one worth posting would be the D21.
2 hours ago, 560DT said:
not what i was expecting
2 hours ago, Dasnake said:
Oh, a tractor, hmm double D, I wuz thinking.....................
You guys...
Wisconsin County Road Signs | These are probably either in ...
  • Haha 5
39 minutes ago, acem said:
DD can be several things.
Duncan donuts
A hwy in south Missouri
A bra size that I like!
Thx-Ace
Just cause they're big don't mean they're purty.  I've seen some big stuff at Wally World that I'd like to un-see.
  • Haha 4
4 minutes ago, DT361 said:
....believe this was taken about 7-8 miles from my house....
Well, that's cool.  I just asked duckduckgo for highway DD images, and there you to.
Upon further review, I'm going to have to recant - power lines aren't there....stuff doesn't quite match.  This image is courtesy of 'Street View'
DD look good to me. That's my wife's size but that's not her pic below!
Well this was certainly a disappointment, not exactly what I had in mind. Then to add to the insult, it was a damn green tractor.
One does have to admire their ingenuity though. Pretty cool.
Old and green I was hoping for young and any host of other colours
Oh! Look JD finally made a 4 cylinder,  OK, they also made a 6 cyl., with their 730.  International very early, about 1911, made a 2 cyl. but they fired evenly,with an even fireing. put, put, put,put, both pistons traveling together.  whereas JD sounds  put, put, coast, coast. i think i'm right? anyway i know there were guys cuting the JD crankshafts, and cam shafts, and rotating them 180 degrees, and welding them back together, with a counter weight in the middle of the crankshaft with 2 stacks, and an even fireing sound, claiming more HP. looking like those double D's, with double stacks, as shown in the top post above.
