Puddle on the deck.
At one point I was thinking something along that line, as I had just put 4 gallons of hytran in the tractor and spilled some there on the deck.
But I sopped it up with a rag and it was bone dry when I went to move some bales. The puddle formed while I was running the tractor.
It doesn't appear to be running down from under the seat, but is coming up from below, which makes no sense.
Surely you can see where its leaking from if its on top the floor , Just run it get it warmed up good and watch it
19 hours ago, FarmerFixEmUp said:
There's a  steel line  under the platform to the left brake. Maybe has a pinhole in it.
This is line is common to rust thru and leak.  Get part # 384822R!! from CNH.  They have about 100 of them in stock right now.
