1066 no rear remotes and 3 point won’t lift
I was spraying  beans with the 1066 when I lost the rear remotes and the 3 point no longer goes up. All the other hydraulics work. Oil is clean and changing the filter did not help. Where do I start troubleshooting? Thanks
Like snowshoe said, pump flange oring  or maybe something happened to pump. If you pull pump make sure jumper tube from filter is installed correctly. Sometimes when installing pump it will push jumper tube into filter housing. Install pump first then jumper tube with new seals from filter side and then the filter.
