D335 engine in a TD9 dozer
td9bcf180
This is a 51 TD9 dozer with D335 engine. Bosch fuel pump but it has only one fuel filter. Shouldn't it have two? (primary and secondary).
Thanks Ian.   The serial # of the dozer says it's a 1951 but I am wondering if the motor is older.  It has a stamped serial #  TDCBM 16175.  Does anyone have a listing of engine serial # production years?
This has been discussed before engine and equipment numbers didn’t match but often they were not far off, unless engine has been replaced I’m putting it as 1944
1944 engine in a 1951 machine.  Guess anything's possible.
So many engines went into other machines and equipment it is hard to match machine to engine numbers
