D282 liner protrusion tool
I have a late d282  without the wide flange on top. From what I read there is a tool that is used to draw the liner in and stop it at the required height. I have a machine shop and could quickly make one of these plates if I had a bit of information from someone that had one or had used one. Can I assume that it is a round plate slightly larger diameter than the liner and is recessed so that there is a lip around the liner that would bottom out on the block leaving the liner protruding the required amount? if so, how may thousands of an inch?
