244 radiator
mark60
Try this part number in your search engine (Google, Bing....whatever you use): 1275079C1
Not positive this is  the correct part number, so verify you are buying the right thing once you get there.
If it IS the right thing....keep your Nitroglycerine handy...they are NOT inexpensive!
Thanks
Mark
I had my 244 recored last spring in Michigan it was nearly 400.  After a failed attempt on repairing the lower tank which was mostly rotten.  They built a new lower tank and recored the rest for that price.  I know if you search there are some Rad shops that guys recommend on here.
Scott
https://www.kumarbrosusa.com/
I don't know if these guys can help or not. I just got a radiator from them for a Kubota B5200 that was literally half the price of anyone else.
https://www.stevenstractor.com/home/shop-brand/mitsubishi.html
Or, maybe see if the comparable Mitsu built tractor has an available rad.
