Farmall Jack Posted June 27, 2021 Share Posted June 27, 2021 I am going to be pulling the rear axles off my 856 and I want to drill the rear end housing so the hy-tran can level between the rear end and final drive. know it was talked here on the fourm but I can't find it. I would l ike to know were you drill the hole and what you hole you drill. If any one has a picture would be great. THANK YOU JACK Link to comment Share on other sites More sharing options...
1480x3 Posted June 27, 2021 Share Posted June 27, 2021 Thought the 56s had the holes. Will have to see if i got the drain plugs. My 806 don't have the holes, so i knocked out the plugs, seems like they were behind inner axle brgs, one bearing to late Link to comment Share on other sites More sharing options...
Farmall1066 Posted June 28, 2021 Share Posted June 28, 2021 Our 1256 does not have lower holes holes, just upper Link to comment Share on other sites More sharing options...
Long Farms Posted June 28, 2021 Share Posted June 28, 2021 Pre '69 56s do not have the flow hole. Drill 1"-1.5" hole using hole saw on bottom of the wall 1" or so above the plug holes. Youll need to have pto out to clean up shavings inside. Link to comment Share on other sites More sharing options...
Farmall1066 Posted June 28, 2021 Share Posted June 28, 2021 That makes sense, our 1256 is a 67 model Link to comment Share on other sites More sharing options...
Farmall Jack Posted June 28, 2021 Author Share Posted June 28, 2021 Thank you Long Farms that is the information I was looking for. My 856 is an early one so not drilled. JACK Link to comment Share on other sites More sharing options...
