Case 5520 trans problems
caseih5220
94 Case IH 5220 trans light comes on while using loader and steering. Checked pressures for steering circuit and remote circuit. Adjusted pressures so there was a 200 psi difference. Problem still exist. Ohmed out switches on side of trans with tractor off. All checked the same. When light is flashing tractor still drives and loader functions work but your stuck in the powershift gear you were in when the light came on. Any ideas???
