560 fast hitch
801486
The fast hitch on my 560 wants to hunt and stick on pressure some times.  I finally realized I probably caused the problem by modifying the fast hitch so it would lift higher for a post hole digger, thereby screwing up the teledepth valve.  I've read that you can replace the teledepth valve with a regular hydraulic valve.  Would that cure my problem and work with the hitch going higher?  If I do change to a regular hydraulic valve will I need to change any of the linkage or the lever.  Thanks in advance.
I replaced the valve with the regular one and just took the linkage off and it works fine
