Def on a case 600 quadtrac
jd63
  • jd63 changed the title to Def on a case 600 quadtrac
All I can say, is good luck.  Not sure how bad they are in Canada, but here in the States the EPA really squeezed down on the shops & outfits that were offering the computer "tunes" for deleted machines.  One thing I've gathered is that a tractor can be that much more difficult, because the engine controller & transmission controller have to communicate with each other, and being able to hack & program them both is extremely difficult, if not impossible, when comparted to reprogramming the computer in a diesel pickup.
Local shop has done a bunch of them
I think every region has a diesel shop that will do it, it's just a matter of knowing who to talk to.
Around here its just a guy that runs around with a laptop to do the job.  Its up to the farmer/trucker to finish the job such as plugging off the EGR and hacking out the exhaust filter.  Kind of makes sense as a physical shop is more of a target.
On 6/11/2021 at 11:37 AM, jd63 said:
Okay
If by chance you find a shop I would suggest your introduction be  ''Hi I'm JD and I'm from the Environment and Climate Change Canada, I'm here to help you" This will help get the correct dialog started for fixing your problem on the Quad.
LOL okay. I’m not a spy but hear what you’re saying, there’s so many places making tractors run better I was just looking for a referral to a reputable person. My tractor is down
