IH 826 S/N 12954
Long Farms
Bought another 826. Needs some attention but decent and honest 826. Hrs seem right for what tach shows. Im looking for an 826 grille and screen and another original IH stamped muffler for it. Part # 530 888R1-R4
18.4x38 clamp-on rear wheels
7.50-16 6 bolt front wheels
Tach shows 4760hrs
Mech seat
Factory open station
TA
2 Hyd
  • Like 7
Changed the hyd oil, hyd filter, fuel filters, installed 2 piece hyd filter cover, cleaned rats nest in air filter housing, new outter air filter, removed hood and one huge rats nest. Getting rear wheels ready to hand weights. Wire harness is just a crumbling mess. Ordered a set of 9.5L15 front tires for it.
Fresh engine oil & filter, new 9.5L15 tires, adjusted front wheel bearings, had to drill and tap 2 broken weight bracket bolts. Ordered new wire harnesses from Porch Electric. Getting ready to get stripped and scrubbed.
  • Like 8
3 hours ago, Long Farms said:
Alot of hassle for 3 orings. Can get alot of areas cleaned up and buttoned up though. Also pulled out the weak hitch pump.
You make things look so easy!!!!
