Farmall 560 diesel mid seat help
Turner03
Previous owner welded a modern style tractor seat on top of the red box. I want it back like original. I want to go with the deluxe seat. I have found the seat and a replacement red box. But I have looked high and low and cannot find that ‘middle’ piece that connects the seat to the red box. Any suggestions? Or magic? Thanks.
i will say this once you get the rubber pieces and all the parts and adjusting rods working on one they dont ride too bad, i still got the original on my 706 and replaced the rubber pieces and got it all working too and its tolerable. Would love to pick up a wrecked air ride out of a semi tho for it
For what it’s worth ,  those rubber shocks are available from several sources but beware of the cheap ones. My two cents worth is buy the better ones from your local IH dealer , about 75 or 80 bucks each. I had my first seat rebuilt by someone else and it rides like an empty cement truck with flat tires going down hill across railroad ties .  Rebuilt my next two myself with the better shocks and they turned out smooth as butter on a hot day .
agreed buy the good parts they ride pretty good
Your right,a working seat  is amazing compared to a bottomed out one.I just took the time to clean and loosen everything up and they are much nicer. Plus I don't run them through the field 9000 miles a hour like a Fendt mowing hay which helps because you never stay in the seat.
