Frank H Posted June 4, 2021 Share Posted June 4, 2021 Anyone know the most up to date part numbers for the rearend bearings and inner axle shaft bearings for a plain 1944 M? I don't know what the non-IH numbers are. What bearings are considered upgrades? Quote Link to comment Share on other sites More sharing options...
cornerpost Posted June 4, 2021 Share Posted June 4, 2021 If a parade queen ball bearing style as it came with fine. Later 560 flat roller Bower bearing will fit. Have seen used on Flea Bay. If Bowers on inner’s looser fit on outer axle bearing is recommended. 1 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted June 4, 2021 Share Posted June 4, 2021 3 hours ago, Frank H said: Anyone know the most up to date part numbers for the rearend bearings and inner axle shaft bearings for a plain 1944 M? I don't know what the non-IH numbers are. What bearings are considered upgrades? my napa has always been able to cross bearing numbers from IH, do you need the numbers? i have an M parts manual. 1 Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 4, 2021 Author Share Posted June 4, 2021 If it's no trouble, I would like to have the IH numbers to cross. I am trying to buy everything to rebuild it all, and have it ready so it's not down for long. Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 4, 2021 Author Share Posted June 4, 2021 It gets used daily. Do the bower flat rollers cross to a modern number? Quote Link to comment Share on other sites More sharing options...
bitty Posted June 4, 2021 Share Posted June 4, 2021 @Dell 1 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted June 5, 2021 Share Posted June 5, 2021 9 hours ago, Frank H said: If it's no trouble, I would like to have the IH numbers to cross. I am trying to buy everything to rebuild it all, and have it ready so it's not down for long. Frank, i did not see this until just now , i will check for you in the AM 1 Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 5, 2021 Author Share Posted June 5, 2021 Thanks. It's not broken now, but I want to get all the pieces ready to pull it apart this fall, then reassemble it in one big push with all new bearings and seals. It leaks everywhere. Quote Link to comment Share on other sites More sharing options...
cornerpost Posted June 5, 2021 Share Posted June 5, 2021 Google Bower Farmall 560 rear axle bearing. A 2012 post that Pete23 replied to should be very helpful. Especially part about installation. 1 Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 5, 2021 Author Share Posted June 5, 2021 I found a set of 560 inner axle roller bearings on ebay, used. The question now I guess for this pair of bearings is, is a good set of used Bower roller bearings better than a new set of ball bearings for a working Farmall M? The rollers don't appear to be available new anymore. Quote Link to comment Share on other sites More sharing options...
Dell Posted June 5, 2021 Share Posted June 5, 2021 Ok here is a sheet I made up on most of the bearing in the rear end of a FarmAll m . Use it for reference only I assume no liability. All the part numbers were pulled from a reference catalog from SKF. The first row or column shows the IH part number the second column is the bearing size the third fourth and fifth show different part numbers for SKFMRC in the actual cross reference part number. Hope this is helpful. 3 Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 5, 2021 Author Share Posted June 5, 2021 Thank you, very helpful! Quote Link to comment Share on other sites More sharing options...
Dell Posted June 5, 2021 Share Posted June 5, 2021 Here is the bear cross reference and seal cross reference I used. Do a google search they are a free pdf down load. 1 Quote Link to comment Share on other sites More sharing options...
cornerpost Posted June 5, 2021 Share Posted June 5, 2021 I was born in 1949. Dad had a 400 he bought new in late 1956. First rear axle bearing was in 1967. Next one about 1974. If you are observant you will probably catch it before damage done. My uncle bought a new 560 after first update package but before flat Bower bearings came from factory. Luckily for him when axle bearing went out Bowers were available. A used Bower bearing will probably outlast new ball bearing. But I would probably go with the new ball bearing on an M. FWIW IH went through the should have used a roller bearing drama on the 1566-86 in the rear axle planetary drive set-up. 1 Quote Link to comment Share on other sites More sharing options...
vtfireman85 Posted June 8, 2021 Share Posted June 8, 2021 @Frank H i am sorry i goy busy and forgot to check for you. Tool little too late but hopefully it can help in the future 1 Quote Link to comment Share on other sites More sharing options...
Frank H Posted June 8, 2021 Author Share Posted June 8, 2021 Thank you! I appreciate it, just gathering parts now, so a few days doesn't matter at all Quote Link to comment Share on other sites More sharing options...
