beachbumtroy Posted June 3, 2021 Share Posted June 3, 2021 hey guys 1948 fcub here c60 motor, just got it started yesterday 6-volt by the way,and in the process of changing or topping off all fluids........ when i ran into the "touch control fluid" its nasty....keep in mind been sittig for at least 10 yrs thou..........so im going to drai and refill but itsaz to use IH touch control fluid......my question is r there alternatives or not? and if so what? appreciate any and all advice thnx bb Quote Link to comment Share on other sites More sharing options...
stronger800 Posted June 3, 2021 Share Posted June 3, 2021 HyTran. (Or yellow tractor supply cheap fluid.....your tractor your call) Quote Link to comment Share on other sites More sharing options...
Redpower1256 Posted June 3, 2021 Share Posted June 3, 2021 Won't make much difference in your tractor. I can no longer stomach the cost of HyTran personally, and have since switched to Shell Rotella HD fluid. But even the "cheap" stuff would work for your Cub. Quote Link to comment Share on other sites More sharing options...
Gearclash Posted June 3, 2021 Share Posted June 3, 2021 An AW46 would fit the need nicely. Halfway between a premium fluid like Hytran and the cheap yellow bucket basic oil. Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted June 3, 2021 Share Posted June 3, 2021 CaseIH Hytran Premium would be the current "correct" fluid to use, but this is a simple, self-contained, old-technology hydraulic system. There are no exotic wet clutches or IVT/CVT units, or even a hydrostatic transmission involved. Literally anything wet and slippery would work here. As long as the bucket is not labeled "play sand" you would be fine. However, Hytran compatible fluid is widely available and inexpensive. Walmart even carries it. Often called "Universal Tractor Fluid" or something along those lines, because it's so easy and cheap to find you may as well use it. It's far and away better quality than what was available in 1947. 1 1 Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted June 3, 2021 Share Posted June 3, 2021 Many people used to use straight SAE 30 motor oil in these types of hydraulics. Any universal hydraulic/transmission oil will work. 2 Quote Link to comment Share on other sites More sharing options...
beachbumtroy Posted June 3, 2021 Author Share Posted June 3, 2021 wow, appreciate all the responses read this went to rural king and the guy there said the same thing and suggested k trans/hydrualic fluid and on back said it was ompatible with cubs that used hy/dran so i got a gallon lol $13.53 :) im happy thnx guys as i said got the 48 running yesterday will top or change fluids this week then test out this pto fingers crossed Quote Link to comment Share on other sites More sharing options...
