966 hydro engine rebuild
On 5/29/2021 at 1:41 PM, Young mechanic said:
I just wanted to check on that. It's really hard to believe that I put in on there positioned just right the first time. Just seemed to easy
   I'm A Christian Man,  My Friends On This site Are Christians,  We Just Say "Thank You Lord",  Because It Is A "God" Thing,  God Is Always Helping Me!!
"He Hasn't Failed Me Yet"!!!!!
Jim Droscha
You are correct, that was too easy.  Usually the last bolt won't start....
The bolts are just slightly off being equally spaced, I think 2 of them are closer together.
As long as all the bolts started easily, its on right.
I always center punched the flywheel and crank makes for a faster assembly no guess work then
