The quest for horsepower
Finney
Looks great. Always enjoy your projects!  Looks like quite a bit of time sitting right there.
55 minutes ago, 1586 Jeff said:
What did you do to keep the flange that mates with the cylinder head from warping as you welded it?
I had it tacked to a piece of steel 4"X1-1/2"X36"
Finney.... give some info on the furnace. Heat exchanger with fan. Is it it wood/coal? And it looks like burns used oil too. Did you build the furnace?
So with the header, are you running that into a turbo? If so how big of turbo? It sure looks cool if nothing else!! You
Interesting.....I spent as much Time looking around the shop as I did looking at the Manifold!...Just like you!!
I was gonna comment on that heat exchanger too.  Looks great.
Stove is 43" long, 22" wide and 41" tall. Corners are 16"sch. 40 quartered, sides, top, front, back and bottom 3/8" plate. Air to air heat exchanger 16" sch. 40, tubes are A106 sch. 80. Plugs in the top and bottom are for sticking a air wand in to clean out. Blower is from a old furnace. Grate is 3"X1/2" angle turned with the point up like a upside down V. Weight is around 1,100lbs.
The turbo bolts to the header. Don't know the size.
3 hours ago, DT Fan said:
Would be interesting to see dyno comparisons between the stock manifold and the 'header'. Looks fantastic BTW.
I will know in a couple of weeks.
  • 3 weeks later...
3 hours ago, JaredT said:
 I hope the 5.9 didnt come out of the pickup in the picture.That's too nice of a pickup  to make it into a donor.?
Maybe they are shoehorning a 8.3 and a roadranger in the dodge .....
6 minutes ago, searcyfarms said:
if its going back in that dodge in the back ground you are going to have to work on the hood @Finney
At the top of this post he said that it was going into a 1066.  Now we NEED pictures!!!
Ooooh boy.  Have a thought for that poor block.  Looks like someone is going to see if they can blow yet another Cummins 5.9 block apart.
Maybe Finney can fab a massive stud girdle system to hold the block together.
